yoseff
  • Full Name
    Jose Dias
    Portugal
    DNA 75, 133, 200
yoseff's Achievements
  1. Own 2 75's, but none of them is colour I understand that there is no way to know temperature on kanthal coils, but technically would not be possible to apply X% more watts for Y seconds disregarding temperature? I'm not a coder, but seems quite easy to achieve for a company that is so ahead in vaping technology...
  2. Personally i understand the concerning behind Evolv's decision to date of not enabling preheat in kanthal coils... For the "non advanced" user can bring some dry hits, but what if it could be turned on by ticking a box that explains the "danger" of that option, stating that it is intended just for the "advanced" user? It could be a solution for the 75, 200 and 250 boards. With so many users asking for it, i think it should be done... (Personally i've been more with SS, but i continue to see that as an useful option) Also i leave the suggestion to create an option where we can hide profiles we dont need to use. Let's say i'm just using 3 profiles, the others could be hide in the device. When needed, just connect escribe and tick a box to "un-hide" Also a question: No new firmwares for devices? Or we need download them separately? (75, 200) I Installed SP8 and for my 75, for example, last firmware is from 2016. Is that correct? (Sorry, been a bit "away" from the forum, but still a proud and happy daily DNA user)
  3. I guess is Cell Soft Cutoff
  4. [QUOTE=yoseff] Read my Disclaimer first: Removed by administration , sorry yoesff [/QUOTE] Why was it removed? A bit too much danger? Worked for me, however i understand that best (and safest) solution is buy new battery Shared with best intention in mind, but understand that safety comes first It had too much of a chance for someone to do it wrong....Murphy's Law, if it can happen it will happen. So yes it was removed as looking a bit risky.
  5. Read my Disclaimer first: Removed by administration , sorry yoesff
  6. Didn't cut it yet. It seems that by using it, the problem has been smaller each day. Also many times i charge batteries inside it, so i didn't bother to do it. About safety... As long as you don't reverse any of the batteries, seems ok to me
  7. That VT75 nano has also that screw in the bottom? (Think they call it cathode or some thing like that) I remember VT75 had some weird problems with that Also what is the value you have in "Mod Resistance"? (escribe) I would clean everything very well, and would use a "shortcircuiter" tool in order to get the right mod resistance. You can look around in forum in how to get something like that, or you can DIY. Did mine with a plume veil base and a brass screw to have that good short circuit and discover each device's resistance. Hope you find solution for that
  8. What number you have in Mod Resistance (In escribe - mod tab)?
  9. It's like that - Some worst than others It's on my to-do list to disassemble and cut a bit of that plastic - but then we must be extremely cautious to put battery on exact orientation. Right now i'm charging batteries in the mod as i have other DNA's to use and it actually charges faster than my external charger. Other than that it is a great mod. Your SS profiles are right? Mine came with wrong profiles, but that's easy to solve.
  10. Glad it solved the issue About the csv's, you can get pretty much any material from steamengine. About that UD csv, i got here in the forum, dont remember the thread. It is from Jaquith. He developed great csv's for SS When i test a csv that works, i usually keep it and later share with people here in the forum who may have problems like yours.
  11. If it is from UD, you can try also this one
  12. Make sure also that you have the correct ss316L csv. My therion was with incorrect profiles. Said 316L but was just in name. To be sure try this ones i put here. One is a profile (jaquithv7 - I use this one with ss316L), and other is the csv from steamengine. Let us know if it solved DNA200-SS_316L__Elite-SteamEngine.c DNA200-SS_316L__Elite-SteamEngine.csv
  13. yoseff
    Therion paint
    Mine is getting off from the body too. Anyone knows for sure what is the material below that paint? I am starting to imagine taking that paint all in the future (when becomes too bad) and polish, for example...
  14. Please check that the material looks like this with close numbers to those. My Therion came with some wrong profiles, and only after i upload the right ones it started to work well on TC You can try this 3 i attach here and see if it start to work well with any of them (I had these 3 at hand and i'm a bit busy, so cannot test them now) SS316L.csv DNA200-SS_316L_DJaquith_V7.csv Jaquith_V7SS316.csv
