Griffin 22 mm by GeekVape evaporator profile - Notch coil SS316L evaporator profile. Here are all the files: logo .. etc. 2 x Notch coil 5 mm 0,2 Ohm iInner diameter: 4,8 mm. Total Ohm: 0,1. Power 35W / 45W preheat, Material profile: custom SS316. I've used 2x 5 mm Notch coils but slightly flattened, If you own a 25mm version of Griffin you will not have this problem. Power may be up - this is the initial experiment, here temteraturata is far from the setpoint. Here is my review, which is unfortunately not in English:
Recommended Comments
There are no comments to display.
