no-glasses.jpg.2af3f4f1bdbaaf62701d1a9aed0832ac.jpgMaximum Visibility. Zero Compromise.
Experience the largest possible text layout ever optimized for a portrait screen — designed specifically to eliminate cropping on the controls and information you use most.
With the Huge Colossus Theme, readability is no longer a luxury — it’s the standard. Every key value, every essential setting, presented in bold, oversized clarity. No squinting. No guessing. No reaching for your glasses.
Built on the powerful foundation of the original Pro Vapers theme, Huge Colossus retains all core features while refining the visual experience. The result? A cleaner interface, simplified structure, and ultra-clear typography engineered for effortless interaction. Big. Bold. Unmistakable.
Pro.Vapers_Manual_EN.pdf
Hope everyone enjoys!
aMir Sirati
Edited by aMirS
What's New in Version 4.3   See changelog
Updated and Redesigned main screen .
Updated to latest firmware and Pro Vapers v12.7 Theme features.
Redesigned Profile setting screen.
Added temperature power field in main screen.
New feature called Auto Fire (Session Mode) in profile setting screen. When Auto Fire enabled, you don't have to hold the Fire button down. Instead, you press it to start firing, and press it again to stop firing. This is useful at low power settings (or with a temperature-sensing coil), especially with high thermal mass coils or e-liquids that need to warm slowly.
mactavish
TWO QUESTIONS:
Sorin
SOLDI
Everything was great—I even had some of your earlier themes—but right now, none of them can be downloaded to the Dna75c because the theme files are too large, except for the last one with the skull, and I'd like version 8.
Francixko
Super boulot, une fois de plus ! Continuez 👌
Et merci pour le partage !
