New for version 2:
- Perfected color choices
- Improved buttons & gauges
- Improved text spacing
- Massive lockscreen wallpaper dump
If you want all text & profile names to fit the theme perfect download my full Escribe Settings.
If you want Replay to work on the newest tanks the needed material curves for the various mesh & wire types are in the Escribe Settings below.
Download Here:
You MUST download & install these Escribe Settings 1st & AFTER that download & apply this theme NEXT.
If you just install these Escribe Settings alone you'll be using an outdated version of a different theme.
CHECK OUT MY LAST THEME HERE -
Edited by BigLarry
What's New in Version 1.2   See changelog
Changed what was initially highlighted.
