The theme is based on my previous topics. It works on DNA75C DNA250C, and in DNA75C/DNA100C does not operate "Power bank" mode.
The theme of VapingBad is the basis theme - here are many changed: icons and there are extra features .. I use his conversion for pre-heat - a very compact solution.
Copy from VapingBad
The TP icon:
default shows on image,
Text status:
Temp Field:
atty\temp as default
Extras:
In Lock Screen down: Current in charge or root temperature in non charging mode. When using a power bank, an icon is displayed.
In Main Screen two resistans: locked ohms and life ohms.
In Main Screen right to Power: temperature of board or output voltage in VW mode.
In Main Screen right to Temperature: Temperature ot last puff
In Battery Screen: Below is shown what current is the charge, and the displayed power indicates whether the fast charge is on: normal charge - 7.1 watts / fast charge - 13.2 watts
New in Version 1.4 - Redesigned battery indication. For example:
Edited by copyman
What's New in Version 1.2 See changelog
Clear bugs, Battery section: redesigned to show / hide battery cells, when we have for example 1 battery, the others are not shown. The same is done for the power bank indication, there is no need to see it at all at DNA75C / DNA100C.
I magnified the font where possible, but there is really no space on the main screen. I am preparing a Light version of the template, with fewer captions and a larger font.
With version 1.2:- Download
