The theme is based on my previous topics. It works on DNA75C DNA250C, and in DNA75C/DNA100C does not operate "Power bank" mode.
 The theme of VapingBad is the basis theme - here are many changed: icons and there are extra features .. I use his conversion for pre-heat - a very compact solution.
Copy from VapingBad
The TP icon:
default shows on image,
Text status:
Temp Field:
atty\temp as default
Extras:
In Lock Screen down: Current in charge or root temperature in non charging mode. When using a power bank, an icon is displayed.
In Main Screen two resistans: locked ohms and life ohms.
In Main Screen right to Power:  temperature of board or output voltage in VW mode.
In Main Screen right to Temperature: Temperature ot last puff
In Battery Screen: Below is shown what current is the charge, and the displayed power indicates whether the fast charge is on: normal charge - 7.1 watts / fast charge - 13.2 watts
New in Version 1.4 - Redesigned battery indication. For example:
Edited by copyman
What's New in Version 1.4   See changelog
Extremely annoying bug fixed once again. When editing the  theme, the default inscription "Hello" appears in the battery fields. Redesigned battery indication.  For example:
Serenity E
Love this! Makes me think of Amiga games for some reason! :D Hope you don't mind my remix... 😛
Paul
aMirS
One of the best. Completely graphical 👍
Sami_mp
excellent work, a very complete theme. thank you very much 😬👍
