I made to be usable for you lot and to see how you can use conditions, gauges, toggles etc work as making themes has a significant learning curve. As a quick start base for you to use and abuse, no rights claimed use/share any of it. Looking forward to far more beautiful theme from you lot.
Things that are not obvious are:
Clicking the profile name on the main screen takes you to atty setting.
Clicking on the profile name in the atty screen let you change profile.
Clicking the Ohm symbol in the atty setting page remeasures your resistance.
Temp is swamped for voltage on the main screen if temp protection is turned off or you have a non-temp sensing coil.
On the recording screen if you click the number you are taken to the most recent puff and if you click on the graph you are take to the field selection screen.
Most icons you can select will show some text in the status field saying what they do.
The TP icon:
default shows on image,
Text status:
Temp Field:
atty\temp as default
Enjoy
  • Like 5
Nicolasan
It's crazy how a theme can change so much the experience with our box mod. Really good! Nice project and very well realized. Thanks!
winky
· Edited by winky
Simply Amazing.
It gave my new DNA75C on my DIY Box a great aspect, but what is more important it solved a TC limit issue that I was not able to fix with stock and other themes.
Thank You @VapingBad it was really precious to me.
Take care
Andrea
Dom
Been using for a week. Really good theme. Good options. Well done.
Made minor changes:
Changed date format to dd/md/yy in locale settings in theme designer.
Also changed Watts to change by .1 steps instead 1 watt steps.
neX
imho this should be the stock theme , lots more options & settings without being difficult to navigate or understand , I would only like to know how to change the date format to date/month/year instead of month/date/year in theme designer , otherwise so far this is my daily driver.
