Pipeline is a bright n unique theme for your refreshment. Battery Indicators & other readouts are designed based on pipeline water level, meters and switches.
METER KNOW-HOW
Center Meter: Battery Indicator.
Left side meter: Coil Power indicator.
Right side meter: Atomizer Voltage Output indicator.
OTHER FEATURES
On Home page: Puff Counter Reset, Replay on/off, board temprature, Power, Record, Save, Replay, Charging/Discharging/Powerbank indicators.
LOCKSCREEN:
Battery indicator is diplayed as the water level inside the pipeline. As the battery drains, water level gets low. While charging, it will display input Amps as well.
USB Data Icon & USB Charging icon on lockscreen turns green when connected to PC / Power respectievely. Powerbank Icon turns red when connnected used as powerbank.
and much more..
Hope you'll enjoy..
Thanks
Manish RD Themes
ManishRDThemes©2021 & PipelineTheme©2021 are private properties. All Rights Reserved. Dubai, United Arab Emirates.
Edited by Manish RD
Added Screenshots
With version 1.0.0:
