Pennywise, Wooden, Glass, Cloth, Escape from Tarkov Editons available under downloads. More will follow! Suggestions or wishes are gladly considered
Pennywise, Wooden, Glass, Cloth, Escape from Tarkov Editonen verfügbar unter Downloads. Weitere folgen! Anregungen oder Wünsche werden gerne berücksichtigt
#Edit by NZ aka RoSeTTe
Thanks to everyone whose graphics I used or edited.
Known Dude from the German DNA Crew: Lukas E.
Special thanks to JMat for the great extension of the standard theme which was used as a base.
A special thanks also goes to George Lucas the creator of Star Wars for this outstandingly legendary film series and the hole House of Vape Crew.
For Patches and Minor update descriptions scroll down.
Für Patches und Beschreibungen kleinerer Updates nach unten scrollen.
New Coil Info screen added with time, battery %, current profile, coil material, cold ohms, live ohms, coild temp, ability to remeasure resistenace, and ability to lock ohms.
New Display menu has brightness adjustment, always on, stealth level, auto lock, auto lock time out, and # of clicks to lock, and ability to set unluck device sequence.
Device screen now had power bank settings, and battery voltages for up to 4 batteries.
Thanks to everyone on the Evolv forum for ideas and themes to give me inspiration for this theme.
Edited by RoSeTTe
More Editions added
With version 1.1.0:
