A basic Cyberdyne Systems/Skynet DNA-C theme. I tried to create a T-800 HUB display you find the old T-1 and T-2 movies for the DNA. It still needs quite a bit of work so this is just a basic Skynet theme. I'm still learning how to use the theme designer so once I get the hang of using the software to make custom themes this theme will have a V1.0.1 update.
Version 1.0.2:
Labelled under Cyberdyne/Skynet Theme
Version 1.0.3:
Labelled under Skynet 2.
What's New in Version 1.0.3   See changelog
Changed a few background images to make the text stand out more. It's better than what it was but working on a T-800/Skynet/Cyberdyne Systems theme for the DNA-C mods is quite tricky.  The theme is for both the DNA75C and DNA250C. I've also moved some of the text around.
Cyberdyne Systems Skynet Theme DNA-C.ecigtheme
1.0.3 Patch Notes:
Miscellaneous - Atomiser -> Current (Amps)  added to main screen.
