Cyberdyne/Skynet DNA-C theme 1.0.3
   (0 reviews)
A basic Cyberdyne Systems/Skynet DNA-C theme. I tried to create a T-800 HUB display you find the old T-1 and T-2 movies for the DNA. It still needs quite a bit of work so this is just a basic Skynet theme. I'm still learning how to use the theme designer so once I get the hang of using the software to make custom themes this theme will have a V1.0.1 update.
Version 1.0.2:
Labelled under Cyberdyne/Skynet Theme
Version 1.0.3:
Labelled under Skynet 2.
What's New in Version 1.0.3   See changelog
Changed a few background images to make the text stand out more. It's better than what it was but working on a T-800/Skynet/Cyberdyne Systems theme for the DNA-C mods is quite tricky.  The theme is for both the DNA75C and DNA250C. I've also moved some of the text around.
Cyberdyne Systems Skynet Theme DNA-C.ecigtheme
1.0.3 Patch Notes:
Miscellaneous - Atomiser -> Current (Amps)  added to main screen.
Recommended Comments
Welcome here in the forum 😃, on behalf of everyone I wish you a lot of fun creating your own themes.
I would like to give you a little tip: always make sure there is sufficient contrast between the information and the graphics in the background.
Hi thanks for the welcome. Yea I’m experimenting with different contrasts between the theme and text/hub. There will be an update at some point in the future once I’ve figured out how to do things properly. It’s all practice at the moment.  I got this Cyberdyne/Skynet theme on my Paranormal at the moment and it isn’t half bad. It does need improvement.
Молодец! Главное не останавливайся, изучай работы других авторов. Со временем все получится!
Edited by zark
  • Like 2
Спасибо, пришлось перевести то, что ты сказал, потому что я не понимаю по-русски, но я буду продолжать тренироваться.
