Pash Posted May 18 Report Posted May 18 (edited) Hello I wanted to test this concept myself but EScribe does not have the functionality to implement. The idea of this TC profile is that like in session mode you set temps and click fire once to activate. When active it goes to "preheat" temp target 60-120C (user set) that is active when consumption is less than lets say 10W (user set) and secondary (user set) "working" temp target for when the drag is detected by wattage going up. With inhale the wattage will rise to keep up the temp of the coil with "preheat" temp and when it goes over a user defined value of 10W, for example, mod switches to the "working" temp target like 160C. End of the draw could be detected by steep enough coil temp rise or hitting the "working" temp target (maybe overshoot detection) or wattage lowering to a preset value. After the end of the draw is detected mod goes back to the "preheat" temp target. Pressing fire button for the second time stops firing and exits loop At the very start while still reaching "preheat" temp switching should be ignored Please consider this profile implementation. I'd like to answer any questions or hear your thoughts Also let me know if there's a way for me to do it myself Thank you! Edited May 18 by Pash
