If you have connected this mod to EScribe on the computer that your using before a backup was made. You can find it by connecting to EScribe then under the "Help" tab you will find your backups under "Backups".Search by date and model from drop down window. Be sure to upload to device once you select it.
While this isn't going to change the firmware version it will contain your .ecg file and theme. The .ecig file is your settings.
