lc.lima12 Posted April 9, 2020 Report Posted April 9, 2020 Hi, Please, does anyone here have CVS for 2 Samsung 30Q batteries for DNA250c? My 30Q pair is barely lasting using 90w with a resistance of 0.12ohm. Thank you, Lucas
dwcraig1 Posted April 9, 2020 Report Posted April 9, 2020 Having the proper CSV file for your batteries will only make your battery gauge and % more accurate. Battery life will not change. There are two settings that effect battery charge life and they are Cell Soft Cutoff and Charge Mode. I'm using 2.75 volts for 18650 cells and 4.2 volts for charge mode, this pretty much gives the most from each charge. There may be a possibility your cells are not genuine, just something to be considered. Using Device Monitor with the cells boxes checked will show your voltage drop while firing, could you post a Snippet of that here please? 1
