Evoxryan Posted July 12, 2019 Report Share Posted July 12, 2019 whats up everyone, i just picked up a Orion DNA Go, and i just had some questions! 1. out of the box the Orion was low on battery life (red light) so connected it to a charger, i noticed it gets pretty hot while charging, is this normal? 2. I have the .5ohm pods, i was told i could use my 25mg slat nic juice in the pod is this right? 3. what would be the best settings for my juice? i dont want to go in and start messing with power and boost not knowing exactly what i need to be doing. Thanks for the Help in advance! Link to comment Share on other sites More sharing options...
stegadon Posted August 2, 2019 Report Share Posted August 2, 2019 I am new to, just bought yesterday, In the box we are told that can be used with salt nic, but i think, and my experience with 0,5ohm 50/50, 50mg nic, Is to hars no mater how you set using your escriber, I have a mod that uses RTA MTL for salt nich and the lowest ohm is 1 ohm coil, with 12watt you get a nice smooth throat hit, but with 0,5ohm, in Orion Dna Go, you get hard burning sensation, which i had the experience, Logicly if you are using 25mg nic, with 0,5 ohm, try to set in the escriber lower down by 3 watt, boost all to 0 (To save the logib=vity of your pod) and warm to 1, try with that but i think you still get quite hars hit on the throat, Right now I am waiting for the orion Q pod which 1.0 ohm, and will set manual in escribe programe the ohm resistence and try vaping that, it should have a nice smooth throat hit with the Q pod. I will get back to you how it goes, Link to comment Share on other sites More sharing options...
