Hyperar Posted April 16, 2019 Report Posted April 16, 2019 Hi, i have a Goon 1.5, and i have had this problem with my two Paranormals 250C and also a Triade 250C, where the cold ohms jump around 0.170 and 0.230, but while firing the ohms stay constant at 0.128, i also used this atomizer with that same coil in another mod and haven't experienced that issue, the ohms stay constant at 0.13. These coils are all Kanthal, and also happened with another set of coils, which i assumed it was a problem with the coils, but with these new ones it's the same. Any idea what might be happening? Thanks in advance
Kitsune Posted April 19, 2019 Report Posted April 19, 2019 (edited) Hello Hyperar, may I ask if you've totally disassembled and cleaned your goon 1.5 as well as cleaned the 510 connector on your mods? As it sounds like you've got a conductor issue. Edited April 19, 2019 by Kitsune Extra clarification
Hyperar Posted April 22, 2019 Author Report Posted April 22, 2019 On 4/19/2019 at 9:27 AM, Kitsune said: Hello Hyperar, may I ask if you've totally disassembled and cleaned your goon 1.5 as well as cleaned the 510 connector on your mods? As it sounds like you've got a conductor issue. Yeah, i look around and it seems a pretty common issue with the Goon 1.5, those who fixed the issue (not all AFAIK) disassembled the whole thing and gave it a good clean, i did it and it works much better, not perfect (reads a little bit high) but resistance not longer jumps, i'll give it another clean to see if it reads resistances accurately. Thanks for your response. 1
Kitsune Posted May 19, 2019 Report Posted May 19, 2019 Your welcome @Hyperar, at least things are getting there for you. Hope that you finally nail it. 1
The Kid Posted July 27, 2019 Report Posted July 27, 2019 My Twisted Messes pro 24 did the same thing. took it apart completely and cleaned ...........all good now
