Im  using for first time temp protection on a 75c , is working fine but if i try to keep firing without  liquid on cotton , temp protection  doesnt stop the erogation ... whats wrong ???
The temp seems ok, cotton should not get burned below 250°C.
Just to be clear... the device will not stop to heat up the coil, it just will lower the power/wattage so you should not expect it to "switch off" or something,
but the power should drop to a point where no vape will be produced when the liquid is fully gone. So in your case from 15 W to maybe 2 or 3 W.
You should be able too see the drop on your device monitor (depending on your theme of course) or in the escribe device monitor.
Did you set the device to the correct material ? If you choose the wrong material then the device will use the wrong curve to calculate the temperature.
And of course this will only work with TC compatible materials (SS (all), NI (200), TI). Not with Kanthal or low Ni alloys.
