johnny_cass Posted November 3, 2018 Report Posted November 3, 2018 Hi i have my battery soft cut off at 2.75 volts and when im getting near 0% my mod will just cut off at 0% even when the battery voltage is over 3.3 volts. Is there any themes out that ignore battery reading and concentrate on voltage. i have two vtc5a batteries in my 250c paranormal if anyone has a csv that would be appreciated.
Chris Musampa Posted November 3, 2018 Report Posted November 3, 2018 The soft cutoff value is the under load voltage (where the battery voltage sags to when you're actually vaping), while the 3.3V is the resting (no load) voltage. I use VTC5As myself, when they reach 3V3 with no load you can consider them empty, its time to charge bud.
johnny_cass Posted November 3, 2018 Author Report Posted November 3, 2018 Oh I understand so the battery indicator is correct then. Thanks for the help.
Chris Musampa Posted November 3, 2018 Report Posted November 3, 2018 You're welcome. The right csv file will probably make it more accurate though.
