Clarke Posted October 6, 2018 Report Share Posted October 6, 2018 i cant figure this out and its driving me absolutely nuts can someone help me here Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted October 6, 2018 Report Share Posted October 6, 2018 If you go into EScribe and open Device Monitor, does the virtual fire button fire the mod (lower right section of DM screen, the little box next to "Puff") ? Does the button on the DNA board still have a tactile and audible "click"? Link to comment Share on other sites More sharing options...
Clarke Posted October 6, 2018 Author Report Share Posted October 6, 2018 28 minutes ago, Spector NS5 RD said: If you go into EScribe and open Device Monitor, does the virtual fire button fire the mod (lower right section of DM screen, the little box next to "Puff") ? Does the button on the DNA board still have a tactile and audible "click"? Yes it does fire on the computer and yes all three buttons click when pressed Link to comment Share on other sites More sharing options...
Clarke Posted October 6, 2018 Author Report Share Posted October 6, 2018 Yes it does when pressed it clicks and yes when attached to my laptop via usb and when I open the escribe and it does fire on the laptop. Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted October 7, 2018 Report Share Posted October 7, 2018 So if it it does fire through EScribe, then something must be going on with the fire button on the board. This is interesting. Did the mod ever work (fire) or is this a crib death? If this happened out of nowhere, I would assume the button has failed or the pull up resistor for it has been knocked off. How many puffs on the mod? Link to comment Share on other sites More sharing options...
Clarke Posted October 7, 2018 Author Report Share Posted October 7, 2018 This is a brand new chip never been fired by push of the button. 0 puffs on the mod. Twice through escribe. Chip only turns on while hooked up to the computer. Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted October 8, 2018 Report Share Posted October 8, 2018 What mod is this? Is this a custom piece? Does this mod use the onboard fire button or external? 1 Link to comment Share on other sites More sharing options...
Clarke Posted October 8, 2018 Author Report Share Posted October 8, 2018 This chip is being installed in a 1590n1 encloser mod uses a external fire button. But the install isn’t finished due to I don’t want to take it completely apart if it didn’t work. Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted October 10, 2018 Report Share Posted October 10, 2018 My guess is this is an assembly error. Take a pair of tweezers and bridge the external fire button pinout of the DNA board where you have your fire button wires soldered. If the board responds, you can then re-check your soldering and wiring to the external switch. Some pics would be great! especially of the external button pinout, your soldering and your external button wire soldering. I have 2 of the same enclosure, using external fire buttons. Link to comment Share on other sites More sharing options...
