onewolf Posted June 10, 2018 Report Posted June 10, 2018 I have an HCigar vt133. When I press the trigger, the display lights up and shows the batteries as totally empty, and won't fire. I popped the batteries into a different vt133, and sure enough, both batteries full and working fine. I even tried another set of new batteries, checked to make sure they're fully charged, and same result. Display comes on, battery indicator reads 0%. Any ideas what could be causing this?
dwcraig1 Posted June 10, 2018 Report Posted June 10, 2018 So here's what I did, I opened my Opus200 and unplugged the balance connector from the board. Battery icon shows empty, firing throws up "shorted" and didn't fire. Hope this is of some help. Gee, I wasn't thinking correctly, your setup doesn't use the plug. Ask for help here: https://helpdesk.evolvapor.com/index.php?a=add&category=1
a_sane3 Posted July 25, 2018 Report Posted July 25, 2018 On 6/10/2018 at 5:20 AM, onewolf said: I have an HCigar vt133. When I press the trigger, the display lights up and shows the batteries as totally empty, and won't fire. I popped the batteries into a different vt133, and sure enough, both batteries full and working fine. I even tried another set of new batteries, checked to make sure they're fully charged, and same result. Display comes on, battery indicator reads 0%. Any ideas what could be causing this? yes mine is.so plz tell me how you solve the problem?
