So i got my hands today on a epetite dna60 connected to escribe and tryied to auto update(not manualy) with the latest firmeare 1.2 v6 or rev.6,at the stage when it was updating the core and error message poped and the device went black and now the device stoped working and escribe says no  device is connected or a cable is loose and windows(i'm using 7x64 ultimate sp1)see a general usb device only...Plz Help!!!
Edited by seashepherd1982
If it is still showing up on USB, the device is still running. Go to Tools->Update Firmware and choose 1.2 SP6 again manually. It should work.
59 minutes ago, James είπε:
it says is not connected so  i can't do nothing....
those are the message details when i go manualy
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
H.z: Exception of type 'H.z' was thrown.
   at N.Jf.JTx.oe(JJ )
   at N.Jf.QW(JJ )
   at O.AF.Y(Cb , Object , Boolean& , Boolean )
   at O.AF.HY.E()
   at O.AF.I(bv , HT , Boolean , Boolean& , Boolean )
   at O.AF.A(Func`1 , Boolean& , Boolean , Boolean , bv )
   at O.AF.ss()
   at O.AC.q(Object , EventArgs )
   at H.xb`1.kk()
   at H.xb`1.kC()
   at H.Jt.JHg.XO()
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.7.2650.0 built by: NET471REL1LAST_B
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
DEScribe
    Assembly Version: 0.0.0.0
    Win32 Version: 0.0.0.0
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/EScribe.exe
DimensionEngineering.Common.Platform
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.Platform.DLL
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.DLL
DimensionEngineering.PluginApi
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.PluginApi.DLL
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.DLL
DEScribe.Branding
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Branding.DLL
DEScribe.Branding.Evolv
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Branding.Evolv.DLL
DEScribe.UI
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.UI.DLL
Evolv.DNA
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/Evolv.DNA.DLL
DEScribe.Core
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Core.DLL
System.Xml.Linq
    Win32 Version: 4.6.1590.0 built by: NETFXREL2
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
System
    Win32 Version: 4.7.2634.0 built by: NET471REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
DimensionEngineering.Common.Windows
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.Windows.DLL
System.Windows.Forms
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
DEScribe.PluginApi
    Assembly Version: 1.4.0.0
    Win32 Version: 1.4.0.0
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.PluginApi.DLL
i
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Branding.Evolv.dll
BouncyCastle
    Assembly Version: 1.8.1.0
    Win32 Version: 1.8.15362.1
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/BouncyCastle.DLL
System.Security
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
SecondLanguage
    Assembly Version: 1.0.4.0
    Win32 Version: 1.0.4.0
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/SecondLanguage.DLL
ICSharpCode.SharpZipLib
    Assembly Version: 0.86.0.518
    Win32 Version: 0.86.0.518
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/ICSharpCode.SharpZipLib.DLL
EquationParser
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/EquationParser.DLL
Microsoft.Scripting
    Assembly Version: 1.1.1.21
    Win32 Version: 1.1.1.21
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/Microsoft.Scripting.DLL
TrueTypeSharp
    Assembly Version: 1.0.5.0
    Win32 Version: 1.0.5.0
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/TrueTypeSharp.DLL
W
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Core.dll
HidSharp
    Assembly Version: 2.0.2.0
    Win32 Version: 2.0.2.0
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/HidSharp.DLL
DEScribe.Upload
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Upload.DLL
SaberUpload
    CodeBase: file:///C:/Users/%CE%9A%CF%89%CF%83%CF%84%CE%B1%CF%82/AppData/Roaming/Evolv/EScribe%20Suite/SaberUpload.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
