vaperoutlaw Posted April 20, 2018 Report Share Posted April 20, 2018 Does anyone know how to change the wattage increments from .1 to 1 on the dna250c? I can't find it anywhere, not even in the theme designer Link to comment Share on other sites More sharing options...
Yorkyboy Posted April 20, 2018 Report Share Posted April 20, 2018 It's a tricky one to explain and not very intuitive. But in the theme designer, 1. Go to the screen that has the wattage displayed. You may have to select the tab 'Temp Sensing Material or Can Replay' depending how the theme is set up. 2. Click on the watts number 3. Click on 'options' under 'source' 4. Change decimal places to '0' 5. Change step size to '1' If you'd rather, I'm happy to change it for you if you save the theme you're using and post the file on this thread. I can amend and post it in a reply. 6 Link to comment Share on other sites More sharing options...
Gory Posted February 2, 2024 Report Share Posted February 2, 2024 Em 20/04/2018 em 13:42, Yorkyboy disse: It's a tricky one to explain and not very intuitive. But in the theme designer, 1. Go to the screen that has the wattage displayed. You may have to select the tab 'Temp Sensing Material or Can Replay' depending how the theme is set up. 2. Click on the watts number 3. Click on 'options' under 'source' 4. Change decimal places to '0' 5. Change step size to '1' If you'd rather, I'm happy to change it for you if you save the theme you're using and post the file on this thread. I can amend and post it in a reply. Thank you my friend , I was here struggling with this too for one hour untill I saw your comment , thank you so much. Link to comment Share on other sites More sharing options...
Yorkyboy Posted February 3, 2024 Report Share Posted February 3, 2024 14 hours ago, Gory said: Thank you my friend , I was here struggling with this too for one hour untill I saw your comment , thank you so much. Glad it helped after all these years! 😁 Link to comment Share on other sites More sharing options...
