Koop Posted April 9, 2018 Report Posted April 9, 2018 (edited) can anyone shed any light on why my new paranormal is doing this tried 5 different sets of freshly charged battery and there all coming up 4% check batterys Edited April 9, 2018 by Koop
Vtecwil67 Posted April 9, 2018 Report Posted April 9, 2018 Is your mod set for two cell operation? I see voltage on cells 3 and 4 , also your voltage is higher than possible for 2 cells . 1
edwinm Posted April 9, 2018 Report Posted April 9, 2018 (edited) I have the same problem with my LostVape 250C after removing the batteries at night for charging. When I placed the batteries back in the morning I noticed that the time was changed to default and started receiving the error "Check Battery". When I place a partially discharged battery it works fine. I did verify that the mod is set to two cell operation. Edited April 9, 2018 by edwinm
Yorkyboy Posted April 9, 2018 Report Posted April 9, 2018 The OP is a member of a FB group I'm in. Seems he's sorted it. Plugged it into escribe and the problem went away
edwinm Posted April 9, 2018 Report Posted April 9, 2018 (edited) Confirmed. I did try a newly charged battery just now and it worked. Thank you! Edited April 9, 2018 by edwinm
cs1981 Posted April 10, 2018 Report Posted April 10, 2018 mine did this, but only after i messed with escribe settings and somehow the battery was changed on the mod tab to lipo from 18650 2-cell. Reverted whatever change i had made and the setting was corrected.
