Boost causing 'Check Battery' at 54%
skineedog
When using the newly introduced boost feature on a 250 board, I get a 'Check Battery' message with 54% battery left. I understand why but think this is because of a limit in Escribe preventing us from entering a higher Max Amp limit. Currently, one can set a max of 28amps. The batteries I am using are VTC5As and they have a max of 30amps. Not to mention, the battery configuration in this mod is parallel so, isn't the amp draw cut in half for each battery?
