So recently i have notice after building, installing, working out hot spots, and allowing to cool back down to room temp. When i fisrt fire my coils in temp control mode instead of a temp reading it displays "off" and not running in tc mode. But i allow my device and rda to cool down and use again later it runs perfect from then on, even after cotton changes and fireing to get the gunk off. Why do fresh build seem to need a "break in" period before tc works properly?
  • 3 weeks later...
Hi,
The resistance is changing constantly in your rda or rdta which means the the 510 connector in your rda screw was casing this issue. try to use proper rda which the 510 was preturd enough to make solid contacts. i also having the issues with the rdta due to its screw at the bottom , i was using  wotofo single coil rdta. if you tight the screw it will read one kind of resitance and if you loose it will read one kind of resistance.
hi
hi new member but i have a uwell crown ss coils in temp mode set ss316L and it works fine have it at 60 watts so i can put my goon dripper on it the goon has ss coils also
