SS316L PROBLEMS
jaymack58
So recently i have notice after building, installing, working out hot spots, and allowing to cool back down to room temp. When i fisrt fire my coils in temp control mode instead of a temp reading it displays "off" and not running in tc mode. But i allow my device and rda to cool down and use again later it runs perfect from then on, even after cotton changes and fireing to get the gunk off. Why do fresh build seem to need a "break in" period before tc works properly?
  • 3 weeks later...
Hi,
The resistance is changing constantly in your rda or rdta which means the the 510 connector in your rda screw was casing this issue. try to use proper rda which the 510 was preturd enough to make solid contacts. i also having the issues with the rdta due to its screw at the bottom , i was using  wotofo single coil rdta. if you tight the screw it will read one kind of resitance and if you loose it will read one kind of resistance.
