How to Change Temperature Setting Increments
TonyB
Le 16/10/2017 à 06:35, X-R4Y a dit :
Open eScribe, Theme Designer, open your screen for editing temperature control settings, select the temperature field -> Source: Temperature -> Options -> Step Size
You can change it to different values (1,2,5,10) to your likings.
Hello,
I' m must be very stupid ,but I don 't find "  Source: Temperature -> Options -> Step Size  "  on escribe and theme designer :- (  ... HELP please
thanks in advance
Edited by EGO 13
Il y a 7 heures, Dimento a dit :
Select inside the Theme Designer the "Screens" Tab and then select the Mainscreen (right side). Then select inside the Screen editor the Temperature Field. On the right side will appear the wanted Settings.
See also the attached Screenshot....
Thanks a lot !! :thumb:  :)
