clayton Posted September 14, 2017 Report Posted September 14, 2017 Does anyone know the watt hours of a sony vct5a please
bmclaurin Posted October 16, 2017 Report Posted October 16, 2017 (edited) Mooch rates it as a 25A 2500mAH cell. Obviously, usable capacity will depend on rate of discharge. Mooch's test results indicate ~2300mAH @ 10A, ~2140mAH @ 25A. His tests use a cutoff of 2.8v, so your results will likely vary if you are using a different cutoff voltage in your mod. https://www.e-cigarette-forum.com/forum/threads/sony-vtc5a-2500mah-18650-bench-test-results-a-fantastic-25a-battery.746719/ Edited October 16, 2017 by bmclaurin
