Veritaswl Posted September 3, 2017 Report Posted September 3, 2017 (edited) I built a coil on an Atomizer, screwed it onto the VT75, and all of a sudden the battery went crazy. The mod will no longer function. Has anyone seen anything like this? The voltage is rapidly fluctuating between 3.7 and 4.2 volts, and when I press the fire button, the device completely resets. Broken.csvFetching info... Edited September 3, 2017 by BrandonTheBard
James Posted September 3, 2017 Report Posted September 3, 2017 This will happen if the battery is not connected / making contact. It bounces like that when it is powered by USB only.
Veritaswl Posted September 3, 2017 Author Report Posted September 3, 2017 I got it to come back, but now if I try to put it in Temp Control mode with nickel it turns off, and I have to fiddle with it to get it to start back up. This also started when I Tried out a nickel build today.
