sykesy13 Posted August 17, 2017 Report Posted August 17, 2017 Hi there i got my first DNA 250 and have set everything up without issue, however the only point i am unsure about is the max input current setting.This came pre set at 28A. What should it be ?. It is a 250 w triple battery mod. As i have set everything up perfectly for myself i do not want it to be all in vain due to a grossly wrong setting.Thank you
awsum140 Posted August 17, 2017 Report Posted August 17, 2017 Well, according to Ohms Law 22 amps would be high enough for input current assuming a full battery charge. As the battery voltage drops, and sags under load, that would increase so 28 amps is probably reasonable. Of course this all assumes you're vaping at 250 watts. 1
