falcon470 Posted July 11, 2017 Report Share Posted July 11, 2017 so having a bit of an issue i built a coil last night worked great constant temperature control regulation awsome was 40 or 4 not sure which says 40 on coil master jig spaceing. as i said worked great temperature was there i just happend to make the mistake of frying that one couldnt resist the temptation to see how high i could take it. built a new coil this morning at 30 on the coil master jig well coil works but absolutely refused to use temperature control i dont get it its the same wire as before nothings touching the post ive had this problem with other builds too cant seem to find what could be causeing it profiles set up right useing ssv ti wire or sweetspot vapor ti wire .5 tried the coeffecint tried their dna 200 profile on website atomizer analizer says .18 then cold ohms .25 dont get it if i hit the fire button then it will update the cold ohms useing a smok tfv8 cloudbeast rba section i just dont understand this any tips would be appreitaed, also my other tank works fine just has a differnt liquid in it same wire had the same probelm with that tank before too then got it to work....... any one with experiance in this please help me........ Link to comment Share on other sites More sharing options...
giz_60 Posted July 11, 2017 Report Share Posted July 11, 2017 The floating pins in the bases of the Smok TFV atty's are known to cause some strange behaviors in TC mode. 1 Link to comment Share on other sites More sharing options...
falcon470 Posted July 11, 2017 Author Report Share Posted July 11, 2017 got ya that explains a thing or two as i did every thing right and it would just work or randomly not work do you know a tank that has a decent rba that doesnt give issues like this? preferably with a high capacity tank Link to comment Share on other sites More sharing options...
GHammer Posted July 13, 2017 Report Share Posted July 13, 2017 On 7/11/2017 at 4:00 PM, falcon470 said: got ya that explains a thing or two as i did every thing right and it would just work or randomly not work do you know a tank that has a decent rba that doesnt give issues like this? preferably with a high capacity tank Expand Steam Crave tanks have always performed well for me. They solidly stand behind them as well. The Aromamizer Plus is my favorite tank now, and the Supreme V2 would be my 25mm choice. Link to comment Share on other sites More sharing options...
