LiFe Batteries
Jaquith
I'm aware they're larger and it is the reason I'm asking. I'm trying to find the smallest LiFe (LFE, LiFePO4) battery that will work on the DNA 200. As am I certain many prefer not to use a LiPo. Simply I prefer the chemistry of LiFePO4 batteries.
Brandon,
I know you're trying to help and for that thanks. However, there isn't anything out there you've tested? Sure you can Series 3 x 18650 LiFePO4 batteries, in that case I'll use my regular 18650's instead. Certainly in 'testing' you guys looked into non-LiPo batteries, didn't you?
There are no 'small' packs, just LiPo's and a few at that.
Instead, most LiFePO4 packs are 30 mm minimum LxWxH cube minimum or are silly in length. e.g. 137 mm (~5.4") and larger.
Examples 3S LiFePO4 packs - http://www.hobbyking.com/hobbyking/store/uh_listCategoriesAndProducts.asp?idCategory=218&LiPoConfig=3&sortlist=&CatSortOrder=desc
A. $13.77 ZIPPY Flightmax 1800mAh 3S1P 30C LiFePo4 Pack ; 54A
link - http://www.hobbyking.com/hobbyking/store/__14061__ZIPPY_Flightmax_1800mAh_3S1P_30C_LiFePo4_Pack.html
Dimensions: 137mm x 45mm x 16mm
B. $17.88 Turnigy nano-tech 2100mAh 3S1P 20~40C LiFePo4 Transmitter Pack ; 42A
link - http://www.hobbyking.com/hobbyking/store/__23815__Turnigy_nano_tech_2100mAh_3S1P_20_40C_LiFePo4_Transmitter_Pack_.html
Dimensions: 97 x 30 x 30mm
C. $15.50 ZIPPY Flightmax 2100mAh 3S1P 30C LiFePo4 Pack ; 63A
link - http://www.hobbyking.com/hobbyking/store/__14064__ZIPPY_Flightmax_2100mAh_3S1P_30C_LiFePo4_Pack.html
Dimensions: 137mm x 45mm x 17mm
137mm = 5.4"
I have the first linked one for testing purposes. Works fine, impractically large.
Realistically though, there aren't really any good small lifepo4 cells right now that I know of. That said, for a few thousand dollars in setup charges any manufacturer that already handles the chemistry will make you calls in any size and shape you like.
So any medium size manufacturer could have one made.
