dwaindablane Posted July 31, 2015 Author Report Posted July 31, 2015 Like all DNA products when you enable stealth mode, you loose the ability to make adjustments.John/James Can you make stealth mode so when firing the device it doesn't display, seems a PITA that you have to disable stealth mode to make changes to settings like watts, temperature etc... All menus should be displaying the screen during setting changes to the times set within the software IMO.
John Posted July 31, 2015 Report Posted July 31, 2015 Just set your firing brightness to 0. This can be done already with the right combination of screen settings.
dwaindablane Posted July 31, 2015 Author Report Posted July 31, 2015 Yeah, already knew that one, but if you wanted to change this whilst out and about I would use stealth mode, wot good in all honesty is stealth mode when you can not make simple changes to menus without first disabling stealth mode. again just my opinion. Cheers for the reply JohnMr Busardo will give you a thumbs up if you do this
John Posted July 31, 2015 Report Posted July 31, 2015 But what good is a stealth mode that wakes your wife?
dwaindablane Posted July 31, 2015 Author Report Posted July 31, 2015 LOL, yeah at least the brightness can be adjusted right.I believe this could be a great feature if done right, and IMO it needs a few tweaks to perfect it, even if it's more options in the software for controlling the stealth mode and whats displayed.
