Kevinl86 Posted August 7, 2015 Author Report Posted August 7, 2015 Hey guys, I'm just curious on how to go about editing the 'New Coil Yes/No' screen in escribe. I've made custom screens for just about everything on the device except this screen. If I edit it, it basically becomes a static image and I never see any new resistance values change when I throw on a new atty. If this isn't possible to edit could you remove it from the EScribe software?Also, can you add the 'Upload Settings' screen in EScribe so I can go ahead and include that in themes if possible? That's the only screen I haven't found editable in EScribe.Thanks!
John Posted August 7, 2015 Report Posted August 7, 2015 We can't edit the upload setting screen... that is hardcoded into the firmware, because you don't have settings while you are uploading them, so there would be nowhere to load the image from...I hope that makes sense. It is also the screen that displays if your settings are incorrect or corrupted.
Kevinl86 Posted August 7, 2015 Author Report Posted August 7, 2015 Thanks John. Yes that makes perfect sense, thanks for clarifying.Any input on how to go about editing the new coil screen or are you saying that is a hard coding as well?
John Posted August 7, 2015 Report Posted August 7, 2015 That's on the list to do, it just takes more doing than other screens because you'll have to define the areas to overwrite with the text.
James Posted August 22, 2015 Report Posted August 22, 2015 I've added the ability to put the new and old coil ohms in a custom location on-screen to the 2015-08-21 firmware.
