dwkillzone Posted September 28, 2015 Author Report Posted September 28, 2015 I received my vaporshark 200 last Wednesday 9/23/15 with a defective battery. Vaporshark went ahead and shipped me another battery which I proceeded to install on 9/26/15. The catch is I am still experiencing issues with the device. I tried charging the device from a computer USB, iPhone wall charger and a iPad wall charger with the same issue. The issue being that the battery and usb voltage's fluctuate and not in small numbers. I called vaporshark this afternoon, they basically told me this is normal and if the battery holds a charge I am in the clear to use the device. Should the voltages be changing as much as they are? My Hana 200 does not do this. Any input would be greatly appreciated.
mknight Posted September 28, 2015 Report Posted September 28, 2015 I think that's e charge, mine does that ... it shows the charge rate (I think) when plugged in, I've never paid it any mind. I use a 2a or a 2.4a charger and when plugged in it shows the voltage being dumped in the battery in real time. ..... I'm assuming
