vapor shark battery discharge problem
glen
I have a vapor shark, battery is set correctly on escribe, Was just using it with 62% charge left on battery, put it down, returned to it a few minutes later and the battery had dropped to 38% charge remaining Cannot see what is causing this, the fire button does not appear to be sticking, anybody out there got any ideas Cheers Glen
Quick update, been charging and the three cells charge at the same rate, when I take few puffs the three cells drop as expected, cannot understand why the battery discharged when not getting used unless somehow the board thinks its in use, have checked all connections on the battery pack and the all appear fine, very strange
