megahtron Posted August 11, 2015 Report Posted August 11, 2015 sent the mod out today, made it easy to access everything so hopefully its an easy fix.. using the mod gave a glimpse of its potential and I gotta say it was amazing
uncle Posted November 25, 2015 Report Posted November 25, 2015 i have same problem...my wismec reuleaux just use a few days... one week maybe...how to solve this problem?????
speed4mee Posted November 25, 2015 Report Posted November 25, 2015 Try to align the batteries properly
uncle Posted November 25, 2015 Report Posted November 25, 2015 I have change 3usb cord and use 3 different type of battery..but i have same problem
Petemate Posted November 27, 2015 Report Posted November 27, 2015 I just received my Reuleaux DNA200 today.Inserted 3x Efest 3000mAh 18650's. When inserting a USB cable the screen lights up but the charge cymbol is not displayed on the battery meter.I can use the data-connection, since I've updated the firmware version, setting etc. - but no luck charging it.Device monitor. The device is plugged in. One of the batteries is discharged. I inserted a 3rd battery with a lower charge on purpose, to follow the balance charging.
uncle Posted November 27, 2015 Report Posted November 27, 2015 Usb current = 0 same problem with my devise
Petemate Posted November 27, 2015 Report Posted November 27, 2015 uncle said: Try to balence your battery first Expand I put the last battery in the charger, inserted all three again when done and had an hours worth of vape. The batteries are now balanced, and for some reason it now charges - problem solved, thank you!I guess there must be a limit to the difference in voltage between the cells before onboard-charging is allowed.
uncle Posted November 28, 2015 Report Posted November 28, 2015 Petemate said: [QUOTE=uncle]Try to balence your battery first Expand I put the last battery in the charger, inserted all three again when done and had an hours worth of vape. The batteries are now balanced, and for some reason it now charges - problem solved, thank you!I guess there must be a limit to the difference in voltage between the cells before onboard-charging is allowed.[/QUOTE] you are lucky.... my device until today cannot be charged via usb even battery show same reading...
Opako Posted December 1, 2015 Report Posted December 1, 2015 At Mod Tab change the Behavior(1st Option) to: "Maximize Puffs" if you set it to "Maximize Recharges" it won't recharge throw USB.
