steeno321 Posted December 17, 2015 Author Report Share Posted December 17, 2015 Hey all I've just decided to use the TF-TI coils in my TFV4 and I am curious if anyone has gotten these things to produce like they are supposed. I plugged in a standard Titanium Grade 1 CSV file for it but it seems to be lacking on vapor production. Has anyone found the sweet spot for these things yet? If so does anyone have a CSV for these coils that is working wonders? Also curious if I should be locking the ohms with these coils and what temperature everyone else is running them at. Thanks in advance! Link to comment Share on other sites More sharing options...
anou Posted December 18, 2015 Report Share Posted December 18, 2015 I haven't ran ti coils but you should lock ohms when using temp control. Link to comment Share on other sites More sharing options...
whitaker2472 Posted December 18, 2015 Report Share Posted December 18, 2015 Unless you have a problem with resistance jumping around you dont have to lock it in Link to comment Share on other sites More sharing options...
jlmr731 Posted December 18, 2015 Report Share Posted December 18, 2015 I have been using the tfv4 TI coil for a while now and like it alot.Now i dont get the clouds like i do from a triple or quad coil, but seems to be better flavor and stays consistent. Plus does not drink the juice like the others. I attached my csv file that seems to work just fine for me (remove the .txt part)Lock in ohms at 0.32, I'm set at 475 f but you can adjust for your taste, i set preheat power at 150w and punch at 9.I do have power set at 70w just seems to work good for me there.Hope this helps you, and im sure everything can be tweakedsmok-ti-coil.csv.txt Link to comment Share on other sites More sharing options...
steeno321 Posted December 19, 2015 Author Report Share Posted December 19, 2015 Thanks for the info. I will try it out and see how I like it. I expected it not produce as big of clouds as the quad or tri coil but the flavor was definitely not there like it is on my Crown or Herakles tanks. Link to comment Share on other sites More sharing options...
