nathanmuntz@yahoo.com Posted December 15, 2015 Author Report Posted December 15, 2015 ok i have a hcigar vt200 everything works on it fine ( after i replaced the battery as it died) but now for some reason e scribe will not find it i have used different usb cables and nothing i also have tried to take out the battery and try it that way and nothing windows does pick it up but e scribe will not. oh and it will not fully charge the battery its a 1300 mah s3 lipo and will only charge it about half way it only show 3.8v on each cell and now it is draining the battery even plugged in any idea?
nathanmuntz@yahoo.com Posted December 16, 2015 Author Report Posted December 16, 2015 i got it to connect now and i charged the batteries in a external charger and it still will not charge the batterys it says it charging but it just drains the batterys now
muth Posted December 25, 2015 Report Posted December 25, 2015 Who makes the 1300mAh battery in the vt200?
nathanmuntz@yahoo.com Posted December 26, 2015 Author Report Posted December 26, 2015 im not to sure its branded hcigar on the battery
muth Posted December 28, 2015 Report Posted December 28, 2015 I've been exploring the world of lipos and, although I am not an expert, I don't trust Chinese made lipos and, I may be wrong but, I think that's what's in the hcigar. The Chinese mod makers also have a habit of calling out the mAh readings as a total of the 3 separate cells (that are in series). So, your 1300 mAh batt has 3 cells with about 430 mAh each. Maybe one of your cells is failing?I would replace it with a lipo that evolve approves of such as the one mentioned in the data sheet. Or here's a link to an excellent lipo: http://www.hobbyking.com/hobbyking/store/__11951__Turnigy_nano_tech_2200mah_3S_45_90C_Lipo_Pack.htmlThis particular one is probably too big for your box but they offer others. Good luck. I'd like to hear the outcome.
muth Posted December 28, 2015 Report Posted December 28, 2015 Nathan, I apologize. I did some digging and saw that hcigar advertises it's battery as having a capacity of 3900 milliamps. So, yes, each cell would be 1300 milliamps. Nevertheless, I still remain cautious around Chinese lipos. Hope you got your charging problem fixed.
