I'm getting and indication of 12.9v at about 94% charge. Well over the 4.2v per cell a lipo should be at. I haven't measured the battery voltage with a meter but shouldn't the firmware stop charging if it thinks the battery is over 12.6v. Should I balance charge the battery on a appropriate charger.
yes once you start to go over 4.20 volts you start damaging the cells. if the efusion is still under warranty send it back. i understand you have to pry up one of the carbon fiber panels, which could be damaged in the removal process. but ultimately you're overcharging your lipo. what is each individual cell voltage in escribe?
