pony555 Posted January 1, 2016 Author Report Posted January 1, 2016 HiI got my VS 200 1 week ago and I have 2 problem.The 510 thread is loose and when I screw on my subtank mini is moving and its not secure. And I also have problem with the fire button. I have to press strong the button because its stop firing for 0,1 second and firing again. So not enough to press until its click.Any solution?(sorry for the bad engilsh)
macz Posted January 1, 2016 Report Posted January 1, 2016 Do you have the same problem for other tanks or drippers? As for the fire button, I would suggest you to contact VS for that.
skat137321 Posted January 1, 2016 Report Posted January 1, 2016 You either try to take it apart and fix it for yourself or you contact VS support. I suggest contacting the VS support since they are a pleasure to work with and they will surely help you.As for the connection issue with a Subtank: I also had that, but it was the only atomizer that gave me those issues. As far as the fire button goes: sadly, from time to time, I also have the same problem with the fire button.
chris_nm Posted January 1, 2016 Report Posted January 1, 2016 When you say the Subtank is loose, do you mean that it is loose even when fully threaded on?Isn't VS using different buttons than the Evolv 'reference' board?
