craigdennis23 Posted January 5, 2016 Author Report Posted January 5, 2016 I've found using tempered or ni205 to be much easier however I've tried using then as a clapton via 28ga core with 32 outer. I'm having issues as one would probably expect. Does anyone do this with success, the temperature feel right ect. To be honest I assumed tthey could be contact per se as the cores don't touch and I gathered that's where the flow was going. Maybe that's my issue? Suggestions? I use ti a good bit and prefer it but haven't order the right sizes to do any fancy coil types with it. Yet
craigdennis23 Posted January 5, 2016 Author Report Posted January 5, 2016 No one using nickel clapton coils with success? Maybe it's a bad idea or won't work and the cause to my issue
randomposter Posted January 5, 2016 Report Posted January 5, 2016 i have been using ni200 claptons (24g core wrapped with 32g). its a much better vape (to me), than dual 30g coils, but i have only tried single coil on a velocity rda because 8.5 spaced wraps on a 2.5mm comes out to 0.07 ohms. its much easier to rewick without deforming the coil, and a dental brush will clean the coil relatively well. make sure you upload a proper csv file from steam engine, it made a big difference. also, using the device monitor in escribe helped me dial in my settings - 88 watts, with 80 watt preheat @ 3.9 for 1s, temp @420. bottom airflow full open, top airflow all closed on the velocity rda.i haven't been able to try ss or ti yet. still trying to perfect ni200 builds.
craigdennis23 Posted January 5, 2016 Author Report Posted January 5, 2016 Very good, I literally just tried a spaced dual coil on the vcmt tank with 28&32 and it's working well. Seems the spacing is still necessary even with the outer shell touching. Thanks for the comments on your experience with it. Was thinking I was way off lol
