mrminimal Posted October 13, 2015 Author Report Posted October 13, 2015 Does anyone have the discharge profile for the Dan 200 boxer mod? It curies the zippy compact 1000 mAh 3s 11.1v 25/35 burst lipo pack. I've googled for it and asked on FB, but haven't found a discharge graph yet. I unfortunately can't do it because I don't own a resistor. Now I'm hoping to fine help here. Wish you all a wonderful vape!
megaton Posted October 18, 2015 Report Posted October 18, 2015 I made a really simple battery discharge "curve" just from 4.2V as 100% to 3.1V as 0% with no points between so the meter shows an even discharge. welcome feedback if i haven't done this correctly/ safely though. Not sure if this is applicable for your boxer, but i'm using this on my 1000mah lipo.https://drive.google.com/file/d/0BxIHq0ODzAiiR2hranBSMmFvWDg/view?usp=sharing
mrminimal Posted October 25, 2015 Author Report Posted October 25, 2015 Thanks, since I haven't found anyone who is willing to share, I had to do it myself.I am gong to pst it now.
mrminimal Posted October 25, 2015 Author Report Posted October 25, 2015 Here we go guys! Finally the discharge graph for the boxer dna200 with the zippy compact 1000mAh 3s 11.1V 25/35 burst lipo pack.hope your Boxers battery display will work correctly.;-)and in the field capacity you have to enter 9.66 wHZippy_Compact_1000mAh.csv.zip
mrminimal Posted November 23, 2015 Author Report Posted November 23, 2015 sy5tem said:arent 1000mah 11.1 battery 11.1 wh ?should be, but there is always a slight difference what the actual battery capacity is. some lipos write 13000mha but only have 1000mha.
mikepetro Posted November 23, 2015 Report Posted November 23, 2015 Stick it in here. There are 17 Battery Results posted so far, the battery results are on the right hand tab visible at the bottom.https://goo.gl/b33IPBForm to enter a Battery Test Result:https://goo.gl/IP9iSAPlease support this effort!
mrminimal Posted November 23, 2015 Author Report Posted November 23, 2015 mikepetro said:Stick it in here. There are 17 Battery Results posted so far, the battery results are on the right hand tab visible at the bottom.https://goo.gl/b33IPBForm to enter a Battery Test Result:https://goo.gl/IP9iSAPlease support this effort!Ive already done it mate.The only problem is that you need also a column for the cut off and maybe a option for downloading the cvs files. and I can't change the values if I want to add something Ive forgotten.
mikepetro Posted November 23, 2015 Report Posted November 23, 2015 Tell me you edits and I will make them.You can also use the comment field for stuff that you feel is relevant, like the soft cutoff.
mrminimal Posted November 23, 2015 Author Report Posted November 23, 2015 mikepetro said:Tell me you edits and I will make them.You can also use the comment field for stuff that you feel is relevant, like the soft cutoff.I am the one one who made the profile for the zippy compact 1000mha.forgotten to enter the ohms and watts.ohms are 0.25 at 40 watts. cutoff 3.10vMaybe you can't somehow upload the csv file as well.Zippy_Compact_1000mAh.csv.zip
mikipik Posted February 7, 2016 Report Posted February 7, 2016 Does anyone have a csv profile for 2x samsung 25r in a dna 200 boxer mod please?
