blueaussie Posted March 4, 2016 Author Report Share Posted March 4, 2016 I tried to change battery in my device. After replacing it won't turn on. The display just lights up vaporshark flashes each time I press the power button. Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted March 5, 2016 Report Share Posted March 5, 2016 blueaussie said: I tried to change battery in my device. After replacing it won't turn on. The display just lights up vaporshark flashes each time I press the power button. Expand double check the balance tap connection. make sure it's installed correctly and firmly snapped in. i had one that looked fully in but was not. is the replacement battery the same brand and size that came out of it? if you're positive ALL of your connections are secure, and it IS an OEM replacement, go into escribe and do a hard reboot and if all else fails, reflash the firmware. Link to comment Share on other sites More sharing options...
