Zfkirke0109 Posted March 5, 2016 Author Report Posted March 5, 2016 So when I hit 15-20% I get weak battery and one my cells is minorly lower than the other two cells. How do I fix this so I have full use of my battery. My battery discharge profile is provided by Volcano and my capacity is 9.99 wh with a cell soft cutoff of 3.09.
Spector NS5 RD Posted March 5, 2016 Report Posted March 5, 2016 Zfkirke0109 said:So when I hit 15-20% I get weak battery and one my cells is minorly lower than the other two cells. How do I fix this so I have full use of my battery. My battery discharge profile is provided by Volcano and my capacity is 9.99 wh with a cell soft cutoff of 3.09.familiarize yourself with how to run battery analyzer then run the test. it will give you an accurate battery meter. as for one of the cells being slightly out of balance than the others, mine do the same thing right before i get the weak battery message (normal). 10 wh's is very close to what the fullymax 900 lipo is. who knows, you might have a battery that is on it's way out???? run batt analyzer and report back on the capacity of your lipo.https://forum.evolvapor.com/topic/65611-topic/
