Releaux only boots when fire button pressed, cell 1 showing 0 on escribe, not in stealth mode.
Releaux only boots when fire button pressed, cell 1 showing 0 on escribe, not in stealth mode. I have taken it apart and I'm looking for a fix, very upset my pride and joy is broken.
It could be something as simple as cell 1 isn't making contact with the positive battery post. Those mechanical reverse polarity rings some time makes connections problematic. Try moving the batteries around or using a different set to see if that helps.
Cheers,
Steve
Is the device monitor on Escribe showing all three cells at 0V? I've never encountered a blown fuse so I'm not sure what would happen but it's my understanding the fuse disconnects all batteries from the board. I wonder if the ground screw could just need tightening? It's the screw in the battery tray behind the white foam plug.
Cheers,
Steve
