Guest Posted June 8, 2016 Report Posted June 8, 2016 OK need someone to help me understand this I am at present using a 0.11 TITANIUM coils in my borase RTA 24 GA . Puch set at 100 watts temp set at 480 D F now I see on the screen 3.94 volts at first witch if I am figuring right is 35.82 amps only for a split second then drops to 2.78 and lower that is still 72.26 watts at 25.27 amps and it is working great but I do not want to hurt the board I only started to pay attention to this when I up dated my attys that seem to need more heat to work I was using 22 GA and but was having a hard time getting up to temperature setting it was doing a good job staying in the 430 /450 range I started running the temperature up now 470/530 24 GA TI I enjoy it much more it's all most like I am pushing the board to its max if any one could help me to understand this better . It would be nice thanks
dwcraig1 Posted June 8, 2016 Report Posted June 8, 2016 The board is spec'd at 50 amps continuous output and 55 amps burst, you are well under that.
Guest Posted June 8, 2016 Report Posted June 8, 2016 dwcraig1 said:The board is spec'd at 50 amps continuous output and 55 amps burst, you are well under that. thanks I was unaware of that little embarrassed I had my mind stuck on input amps not output changes everything the board is not even working hard were I us it
