From what i've seen, it will not fit. At least without heavy modifications. It is 23mm in thickness and you have 21mm inside the VS. Even if you solve that problem you will have to do a new door as you will not be able to fit the original (battery would protrude a lot from the box). You may have to stick to a 900/950 mAh battery.
