Cant change profiles!
Error989
I recieved my VT75 Nano today and decided to add support for 316L Clapton wire since I love using it. I made the material profile with Steam Engine and it works perfectly. I also updated the firmware since EScribe had a pop up thingy that asked me if I wanted to and since I did all that I can not access profiles on my mod. I could do it before I played around with EScribe.
When I lock my device and try to change the profile with + or - buttons it just says "locked click 5x".
Coil locking, material changing and stealth function all work as they should but I can not change the profiles at all! Cant even access the "menu"
Things I have tried to fix this issue:
- soft and hard restart (hard restart doesnt even delete my settings)
- adding more materials to the mod
- downgrading firmware to an older version
- factory reset
- trying different battery and cleaning the terminals and battery cap
- adding more materials to fill up all the profiles with different wire
(I tried most of those options multiple times, with and without a battery in my mod)
It seems like it's a software problem, is there a fix I can do to fix it? Does anyone have factory VT75 Nano firmware I can try? Or is it EScribe bug?
To change profiles start with fire button "unlocked"
Press and hold the + and - buttons at the same time to "lock power"
With power locked press the + or the - two times quickly and the profiles will change by pressing the + or -
Perhaps re lock power when done...by pressing and holding the + and- at the same time.
Thanks for help :) I figured it out thanks to you, I had Temperature-Dominant setting on so I couldnt do that. When you said lock power it took me 1sec to figure out what I did wrong.
Is there a way to change profiles when in Temp-Dominant mode?
edit: this sounds to me like a bug still... Changing profiles works without Temp-Dominant mode but with it it doesnt.
edit2: I figured out what's the problem. If you apply new settings to your mod and the first setting that pops up is Temp-Dominant you wont be able to change profiles.
