Aria Solara / anarchist DNA200 Hot front panel/bad ohms
Hi,
I've run in to an issue with my solara DNA200, the ohms read way off, and the front panel tends to heat up a lot.
Has anyone encountered similar issues with this mod ?
Could it just be a bad soldering job ?
Thanks for your help.
hi versus158. the solara might be relying on the 3 board screws for a 510 ground. they might have come loose creating a weak connection, reading wrong ohms. if the device is still under warranty you can return it to the vendor for a replacement or you can open up the mod and see if what i stated is the problem.
